| | | Forums66 Topics128,026 Posts1,055,399 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Well, since the oil pan is already on the engine, you've got a problem- - - - -those bolts are supposed to go through the front main bearing cap and screw into the threaded holes in the timing cover. The stovebolt engine was designed that way back when it was a common practice to adjust the main bearing clearance with shims during an "in the frame" overhaul, and with the engine in the car, those bolts were difficult to reach from the front. When they stopped adjusting the mains with shims in mid-1954, they didn't change the orientation of the bolts. Jerry
