| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | correct, the 216 and 235 bellhousing will NOT fit a 292. there are two different bellhousing openings... the sm420 diameter centering collar is smaller than say an sm465 or T5 centering collar. so you will have to locate the approprate size for your needs. and yes the more modern bellhousings will fit any L6 and any V8 bolt pattern. therefore any modern automatic tranny will fit any L6 or V8. the bolt pattern of all the modern trannys is the same to the bellhousing. if you run a T5 w/ a 292 you do not need to cut the centering collar tube as you would on a 235 application. sorry the foot start has to go but i left the foot bolted in situ just cause.
rather than answer all your questions do a search on the topics you ask about, they have more than likely been asked b4 when you get to the point you need to fit items in the engine compartment you'll know to ask like http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=011073#000000
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
