| | | Forums66 Topics128,195 Posts1,057,380 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | In heat the waterslide will last longer. Best if you can spray them with clear urethane after you apply them. The peel & stick will start to release on the edges and once that happens the curling accelerates. But the waterslide stuff isn't the same heavy gelatin we used. It is all high tech now. You can make your own you know. I explained how I do this a couple of years ago when I was re-imagining the 52 speedometer. You can see the whole pageant here: https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1343677/1.html
