| | | Forums66 Topics128,132 Posts1,056,376 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | DOT 5 should NOT be confused with 5.1 brake fluid Since DOT 4 and 5.1 are both glycol-based brake fluids they are compatible with each other, which means they can be readily mixed without harming your brake system. It is important never to mistake DOT 5.1 (glycol-based) with DOT 5 which is silicone-based and should never be mixed with any other DOT fluid. https://epicbleedsolutions.com/blogs/faq/whats-the-difference-between-dot-4-and-dot-5-1-brake-fluid
