| | | Forums66 Topics128,050 Posts1,055,672 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | Remember to tighten the bolt through the front bushing after the weight of the vehicle is on the rear springs. This eliminates the twisting pre-load on the rubber sleeve between the inner and outer steel sleeves in bushing assembly.
Rusty
