8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible),
67
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,014 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | You can use the original switch and a push button starter switch like the 49 and 50 chevy cars had but the aftermarket switch with the "ACC" post can be very handy if you ever go to an alternater or modern accessories. I know someone will chime in on one wire alternaters but they suck; much better to excite with a lamp or wire from the accessory post. I really like Phil's 53 GMC idea. If you could rig up a pivot (the original uses the 6 bellhousing) and incorporate the old foot button that would be double cool.
Evan
