I'd like to keep the stock pedal but don't know if I need to totally revamp. I'm using a small block with an Edelbrock and a 600 cfm Holley. Any ideas on how you guys hooked up your linkage and what pedal setup you used would be appreciated.I'm lost!!
Lothar
