| | | Forums66 Topics128,077 Posts1,056,012 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Rebuilding valve setting is on a cold engine.
Then hot normal operating temp:
The .012” on the intakes generally accepted on all engines ( hot )( GMC)
The .016” vs .020 on exhaust (Hot) varies by the cam. Also serial number change over is given in the manual
