I am put a 350 in a gmc 1/2. I am using a after-
market cossmeber. also using turbo 400 trans.
with a aftermarket trans mount. what is the best
way to get the motor in and make sure everthing
is square and in the right place. should motor
and trans go in together? has you can tell I am
new at this but confudent. that I can do it. I do
know the crossmember need to be cut to fit inside
fram rails. also using stock stearing and front
axle. any help or suggestions would be so great.
