I just installed the passenger side one and didn't notice any problem with the step that you're seeing. May have been a different supplier, but I did notice the angle on the rocker end was a bit off. Just bent the tabs toward the rocker to adjust that.
The end you're showing looks like the one that goes to the tranny opening, because I don't see the reinforcement around the hole where the cab bolt goes thru the floor. Are you installing it in the right direction? The tranny cover is recessed a bit, so needs more of a step in the floor support than the outer end. The pic I borrowed from RockAuto shows that the rocker end has three tabs, but only two on the transmission end.
You can flatten that step a bit if you need to with a hammer and a sturdy anvil. Beat on it and check the fit, and beat a little more if it needs more adjustment.
[on edit] Added a couple more pictures of my cab support clamped into position.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
