You should be able to remove just a few boards without removing the bed. Just unbolt the strips on either side of the damaged board and pull it out. The ones that are bolted thru the frame, however, would have to have those bolts removed as well. I still don't think you'd have to remove the bed even for those boards.
Kevin
1951 Chevy 3100 work truck
Photos
