| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2017 Posts: 82 Shop Shark | | Shop Shark Joined: Nov 2017 Posts: 82 | well I figured I would come back to say hello and see if I could find some insight on the pickle I am in. I was here in 2017, and since then my beoved stovebolt ( 1952 3100 panel with a 1958 235 I-6 engine) has cultivated a love / hate relationship with me. a couple years ago it spun a crank shaft bearing . and I have been stumped on getting it fixed. I have figured out I am going to have to fix it .. but what way do I go . its stored 2.5 hours away from where I live ,as I live in an apartment and can't work on it here. so that in it self is another problem.. the 235 engine that some one put in it has had a bad life . it has modern bearings but some one used shim stock to give space to the bearing inserts . and blue silicone to seal up the oil pan instead of a proper gasket.... crappy work if you ask me . I learned from the plastic guage measuring procedure that at least one of my crank journals are over the limit and the others are under the limit but didffent sizes. so I am wondering if I have a boat anchor instead of a useable engine. I am wondering if the machine shop expences would be more than worth it to get this engine right assuming it is good enough to work with in the first place. I am also wondering if it would be better to lean toward a 292 I-6 or small block V-8 swap ? part of me wants the head ache gone and part of me doesn't want to sell it. have any of you been in a simular delema and/or can offer insight? | | |
