Thanks Kevin!
Progress on the hood, the bead details in the brace are offset on the ends to match the hood opening flange. So we use a Vernier protractor to find the angle, and transfer that to our panel. This is where the transition of the taper starts..
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/18/IMG_6674.JPG [/IMG]
Once tapered, the excess is removed from the bottom side and the outer seams TIG welded in place.
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/18/IMG_6685.JPG [/IMG]
A piece of round stock has a radius added to serve as a hammer form for the beads. They are hammered around and excess removed from the back side..
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/18/IMG_6688.JPG [/IMG]
A piece of 16 gauge cold rolled steel is trimmed to fit and TIG welded in place.
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/18/IMG_6691.JPG [/IMG]
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/18/IMG_6693.JPG [/IMG]
Welds dressed and media blasted..
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/18/IMG_6696.JPG [/IMG]
The bend line is transposed from the original. As this bend is slightly convex, it was started using a tipping wheel on the bead roller to a 45* angle, and then finished on the mag brake.
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/18/IMG_6706.JPG [/IMG]
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/18/IMG_6708.JPG [/IMG]
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/18/IMG_6709.JPG [/IMG]
A reminder of the carnage we are repairing:
VIDEO
A profile template is made prior to cutting out the old....
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/18/IMG_6713.JPG [/IMG]
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/18/IMG_6714.JPG [/IMG]
[IMG]
https://hosting.photobucket.com/images/y167/rmccartney/18/IMG_6717.JPG [/IMG]
