| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You probably don't have the shoes adjusted correctly. There are 2 adjustments on each wheel on the Huck brakes. They are all right hand threads. Adjust each one till you get a heavy drag. Then back it off about 4 notches. The same with the Bendix brakes one adjustment. You will still have a small drag but they will seat in & be OK. If after you get a good pedal you can back the adjustments off a little if it bothers you.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
