2 members (Rusty Rod, porsche),
64
3
Mod | | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Soak the whole thing in evaporust for a couple days Rinse it well and blast it out with air That stuff is like magic and works okay on aluminum oxidization too.
And it’s not a nasty chemical it’s environmentally friendly depending on the metal being cleaned because it binds to the oxide of the metal So if you clean iron or aluminum you can dump it anywhere If you clean lead parts then maybe not so much -s | | |
