8 members (homer52, tclederman, Gdads51, Mike B, 78buckshot, Sjm, TooMany2count, 52Carl),
95
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,263 Posts1,058,333 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,942 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,942 | It's easy to fit an later model choke cover to an early Q-Jet. The problem is finding one for a Chevy engine that has the integral choke in the carburetor. Most of the OEM Chevy carbs have a divorced choke mounted to the manifold heat riser passageway. I have used a carb for a Buick 350 at times, and converted the choke cover to the electric heated type. Don't use the gasket under the cover- - - -it prevents the heater coil from getting a ground, and plug off the vacuum port to prevent a constant leak. Route the voltage through an oil pressure switch so the choke heat shuts off in case the engine stalls during warmup. Jerry
