| | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It may be some sort of coating burning off. I assume all lights are working? I believe the switch has a thermal overload breaker. If it does or it's fused, You are good to go. The "spring" is a coil to act as a rheostat/resistance to vary the voltage to dash bulbs, as a dimmer. 30 ampere thermal circuit breaker in the light switch | | |
