0 members (),
40
2
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | It may be some sort of coating burning off. I assume all lights are working? I believe the switch has a thermal overload breaker. If it does or it's fused, You are good to go. The "spring" is a coil to act as a rheostat/resistance to vary the voltage to dash bulbs, as a dimmer.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
