Brothers Truck supply has a video on you tube on how to replace the ball type tie rod end with the new current style tie rod ends that are available. He puts the steering arm in a vise and grinds off the ball and then grinds the stub down to the arm. Then they are pressed out from that side using a shop press. I plan on doing mine this way.
