| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,782 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,782 | Cast iron Powerglides do not have a modulator, so there will be no vacuum loss there. Once the brake booster charges up on startup there will be no vacuum loss until you apply the brake. If you're not dancing a jig on the brake pedal, no problem there. Are you sure the vacuum piston is raising and letting the power valve close? There should be a slot in the carb base gasket that allows vacuum to get to the power piston- - - -some aftermarket gaskets don't have that slot. The OEM gasket has four slots, so it's idiot-proof- - - -no way to install it wrong. Jerry
