2 members (Shof, crenwelge),
178
2
Mod | | | Forums66 Topics128,281 Posts1,058,487 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2019 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2019 Posts: 36 | I would remove the sender wire and ground it to a good ground. The gauge should show full. That will rule out the gauge as being bad. Clean the contact on the sender and wire connector to it. See if that works. if still not working . Take a jumper wire with alligator clips and install between a good ground and the ground connection of the sender. If that works then the ground wire is bad. If still not working the sender is bad. | | |
