0 members (),
145
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13429 12/30/2003 3:56 PM | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | Wleding cast iron can be tricky but worth it. Naturally, surface prep is important. Use a very hot arc but for very short distance. Overfill. after every inch, stop and release tension with a needle gun. This will last as long as original material.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
