| | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,273 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,273 | What Jerry said. NPSF = National Pipe Size Female (more commonly indicated as NPTF for National PIpe Thread Female). Adapters are easy to find at nearly any FLAPS or Hardware store. Another sealer would be "Gasoilia" made specifically for fuel and gasoline. Pipe threads will seal without a sealer, but you have to tighten them till your eyes bug out or the female fitting cracks. Without a sealer, you also run the risk of galling the threads. Bottom line is use a sealer (not JB Weld).
