What color stripes did you put on the frame? If you drop the suspension height that far without notching the frame rails, the axle will hammer the frame every time you hit a bump. Then you'll have to deal with the bump steer caused by getting the drag link out of parallel with the ground. Making one major modification usually creates two or more problems you didn't anticipate, and some of them can be deadly dangerous.
