Cleaned up rear end. Bearings and gears in good shape. Set backlash in ring gear. Thrust pad is a little worn. Looking for new one. Anyone know how to check clearence between propeller shaft and bushings. Also looking for u joint seals and specs for u joints Thanks in advance John
John 37 Chevy 1.5 ton 17 Dodge Brothers Roadster 23 Dodge Brothers Touring 23 Dodge Brothers Coupe 73 Plymouth Scamp 2 dr
