7 members (TUTS 59, Bill Hanlon, Otto Skorzeny, 50Chevy3100, cmayna, UnclePaddy, 1 invisible),
129
3
Mod | | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If after you get it to alignment specs and it is still twitchy check to see if the power steering pump and gear box are a match. A 1300psi GM pump will make an 850psi Ford box write horror stories. Also check to see if the monkeys used a quick ratio steering box off of something like a Trans Am rather than a passenger car/truck box. One is around 16:1 while the other is around 24:1--- big difference.
Evan
