Looking to replace the pilot bearing pressed into the flywheel for a 1964 C-60. The bearing is marked ND 23205. I tried crossing this but did not come up with anything. Does anyone have a cross reference for this number?
Also, if anyone knows a part number for the flywheel ring gear that would be helpful also. Local parts houses list a ring gear for the smaller light duty 168 teeth flywheel.
