7 members (Nick in Manitou, Pre '68 Dave, cmayna, carbking, greenie-reddy, Oswald, 66flea),
362
2
Mod | | | Forums66 Topics128,160 Posts1,057,050 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | The only gripe I have with that procedure is the use of that bolt-on wheel spacer. If I'm going to space a wheel out, I use a solid steel ring and longer lug bolts instead of using a bolt-on spacer. Most spacers are aluminum, and I just don't trust the idea of a lug bolt that doesn't tie the whole assembly together as a solid assembly. I have made round track race car caliper brackets by holding a caliper and pads onto the disc with air pressure and mocking up the caliper mounting brackets with heavy cardboard and an X-acto knife, then transferring the template pattern to a piece of steel and whittling it out with a Plasma cutter. Jerry
