Wondering if it was percolating from intake manifold heat. Do you have a phenolic spacer between the carb and intake manifold ?
Also, wondering if your heat riser is stuck and you are pushing hot exhaust through the manifold crossover?
Steve
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done
In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
