Try the idle mixture control screw at 1 1/4 turn on a fresh engine. Once you get 500 or so miles on the engine, should be able to get it down to 1 turn.
Hand throttle cable brackets are tough to find; since this is a non-stock application - make one, not that difficult.
Jon.
The Carburetor Shop
