Winter is Coming
47 and early 48 had the bar follow the recess. After that Chevy changed it to angled like yours to reverse the handle pull direction as 52Carl said. Reproduction units only come in the angled configuration. If you want them horizontal you'll have to find some original 47 relays or do what I did: modify 1965 relays:
