| | | Forums66 Topics128,281 Posts1,058,476 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Mine worked fine and kept the temperature constant, up hill and down dale unless I moved the "warmer" knob. Kept the cab toasty down to about 10 deg. F. Then cardboard had to be put in front of the radiator and a 195 thermostat but even that was marginal below zero. We're moving into that kind of weather now where I am. Seven degrees this morning. The later deluxe heaters had a door on the front that could be opened to recirculate the air in very cold weather. I passed one by in the junk yard years ago and have regretted that many times. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
