Register Log In
The Stovebolt Site Forums The Shop Area Driveline Speedy sleeve for stock 1/2 ton rear axle oil seal surface
Forums Active Threads
4 members (MNSmith, baldeagle, moparguy, KEVINSKI), 118 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface
posey #1337310 12/11/2019 7:24 PM
Jarvisburg, NC, USA
tclederman Offline
tclederman
Offline
Jarvisburg, NC, USA
I am not sure that this is the rear wheel seal you are referring to.
Here are the specs for that seal
Here is another brand of that seal
Is that the seal?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban
1954 3104 5-window pickup w/Hydra-Matic
The 216 and early 235 engines are not "splash oilers" -- this is a splash oiler.
Copy Link to Clipboard
Entire Thread
Subject Posted By Posted
Speedy sleeve for stock 1/2 ton rear axle oil seal surface posey 12/09/2019 2:11 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface tclederman 12/09/2019 2:19 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface posey 12/09/2019 2:43 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface EdPruss 12/09/2019 3:56 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface posey 12/09/2019 4:24 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface truckernix 12/09/2019 6:30 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface posey 12/09/2019 6:54 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface EdPruss 12/10/2019 2:56 AM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface Hotrod Lincoln 12/10/2019 10:41 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface posey 12/11/2019 4:22 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface tclederman 12/11/2019 7:24 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface truckernix 12/12/2019 1:54 AM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface posey 12/12/2019 4:26 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface tom moore 12/12/2019 2:28 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface posey 12/12/2019 6:59 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface Hotrod Lincoln 12/12/2019 7:08 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface tom moore 12/12/2019 7:58 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface Hotrod Lincoln 12/13/2019 1:32 AM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface Dusty 12/13/2019 2:15 AM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface tom moore 12/13/2019 12:20 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface Dusty 12/13/2019 8:07 PM
Re: Speedy sleeve for stock 1/2 ton rear axle oil seal surface truckernix 12/14/2019 3:03 AM
Moderated by  Dusty53, SWEET
Switch to Flat Mode
Show Likes
View Profile
Private Message
Website
Follow User
Forum Posts
Forum Rules · Mark All Read Contact Us · Forum Help · The Stovebolt Site
