| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | That setup was used on long wheelbase trucks because the full torque tube system had problems with the extra length. If you try it on a SWB 1/2 ton, the open driveline section will be too short to work properly- - - -there will be some radical angles involved which will cause vibration and/or premature universal joint failure. Jerry
