0 members (),
122
3
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 4,535 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,535 | I bought a cheap one on eBay for about $20. It uses air from your compressor to create a vacuum in a canister you attach to your bleeders at each wheel cylinder. It comes with a fill bottle for the MC. I used it on my other truck and it worked good, but not on my ‘52 1/2 ton so I don’t know if the fill bottle will work. It will drain the MC in a hurry so be sure to fill after each wheel.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
