| | | Forums66 Topics128,087 Posts1,056,340 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I would consider what HRL suggested regarding motor mounts. Not that they are loose but where they are located. I have seen some conversions that are using the "bird leg" front mounts and a rear mount for the TH350 transmission. With this configuration there is an extreme distance between the mounts and can cause the engine to torque over to one side which may cause the throttle linkage to bind up. If you are using the "center" mount position on the engine with the rear mount it is likely OK and would look for another cause. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
