I will give it a try.
I use to park the vehicle close to the garage door so the headlights would reflect off the garage door.
Then I would crank the engine over and watch how much the headlights would dim down while engine was cranking.
If the headlights would dim down to nothing I would suspect the battery was no good or there was a bad connection.
