7 members (Guitplayer, Peggy M, Hotrod Lincoln, Maybellene, Jaison, 55shaker, Gray_Ghost),
65
3
Mod | | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | You'll need to remove the sector gear and center the steering wheel and gear, then put the sector gear back in place. You likely reassembled it one or more teeth off.
