Jack up one wheel after you put the two speed in high, count revs. Most truck two speeds are all geared slow or slower, so adding some kind of OD might be the best solution. Also depends on what engine, you have . 69Cuda must have a V-8 judging by his RPM's, so a 292 will cruise at a lower RPM.
Ed
