2 members (Otto Skorzeny, 3B),
131
Mod | | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 4,542 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,542 | I would double check the wack in the front that you mentioned. You may have to pull the wack on the front a bit to get that dent out. Once your sure the front edge is straight then you can think about shrinking.
I have used a oxyacetylene torch with the smallest top to shrink with success. Like HRL said, heat a dime size spot cherry red, then I take a hammer and lightly tap the area around the spot to massage the excess metal into the spot then quench. I then cool the panel before heating another spot if required. It may require several spots to eliminate the excess metal.
It’s fairly easy once you get the process and practice it a few times. You’ve got the talent, I’ve seen your work.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
