| | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i used a motor mount kit and cross member from chassis engineering in my 49. mounts bolt in and crossmember bolts up to original location once rivits are drilled. it went fairly smooth although did have to move motor mounts 1/2 in forward than the measurements they gave in the directions.good clearance everywhere. although ther instructions say with stock steering the box needs moved out slightly. i have also used their pacer front end kit and just got done installing their bolt in rear end kit which is really a slick set up gave it a 5 in drop and a real clean look to the rear of the frame. i would definately use their products again......whid 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Entire Thread
AD: I6 to V8 Advice, Pointers Needed
| 51 KY 3100 | 10/30/2005 4:27 AM |
Re: AD: I6 to V8 Advice, Pointers Needed
| WE b OLD | 10/30/2005 3:25 PM |
| 48bigtrucks | 10/30/2005 4:18 PM |
| Grigg | 10/30/2005 4:19 PM |
| OldSub | 10/30/2005 10:25 PM |
| nvrdone | 10/31/2005 1:14 AM |
| 51 KY 3100 | 10/31/2005 2:40 AM |
| ohpants | 10/31/2005 6:25 AM |
| OlBlue | 11/03/2005 5:31 AM |
| Kimberly McDowall | 11/03/2005 4:08 PM |
| atomarc | 11/05/2005 7:08 AM |
| david dyehouse | 11/07/2005 5:20 PM |
| Hot Rod Dad | 11/10/2005 10:04 AM |
| ZB3 | 11/10/2005 4:02 PM |
| 48bigtrucks | 11/11/2005 2:49 AM |
| OldSub | 11/11/2005 6:32 AM | |
