2 members (Otto Skorzeny, 3B),
131
Mod | | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Getting an Oxy-Propane flame adjusted down to a fine enough point to shrink with might be a challenge. An acetyline rig with a #0 tip allows me to heat an area about the size of a dime or smaller red hot, then quickly quench it with a water-soaked rag. Shrinking is mostly used to correct "oil canning" where the dented metal has been stretched beyond its natural "memory" elasticity. Rough out and "metal finish" most of the dent out with a hammer and dolly, then shrink the places that refuse to go back to their original contour. Resist the urge to heat before you do the necessary hammer and dolly work to achieve a contour that's very close to original. Jerry
