I would disconnect wires from the turn signal switch and start over with each light, checking running light function. Make sure each one is on when parking lights are pulled on. Once that is good, run hot to the bright element in each bulb one at a time and make sure all the other lights stay on. If not, you probably have a bad ground somewhere. If that all checks out good, then re-visit the turn signal switch.
