Thanks Hambone! Found a good video that helped identify wires and pins. Not sure it has helped me figure it out yet, but I'm beginning to think I may have ground issues. While I was testing, the light switch was not mounted in the dash and from the video I'm thinking it lacked ground. Going to pull the column and replace the column harness and then make sure everything is properly grounded. Here is the link to the video if anyone is interested.
Larry
