| | | Forums66 Topics128,035 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not know about 1957 (so, you might want to ignore the rest of this post).
You can remove the Hydra-Matic transmission and straight 6 engine out the front of an 54/55st A-D truck , as “one piece”: - make sure your lift can handle the total weight - remove the hood - remove the grill - remove the radiator - remove the radiator housing - support the engine transmission “as appropriate”, and remove the rear-engine and transmission cross members - disconnect the driveshaft - slowly/carefully remove the transmission-engine assembly - say a prayer, if you believe in the power of prayer
Take photographs. | | |
