0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | All I will add is, it is not the carburetor. "Its never the carburetor." Check the points and associated ignition parts as Martin recommends. Even if it turns out to be the carburetor, they are difficult to diagnose and taking them apart is tedious. Save that for last when troubleshooting engine problems. You need to check everything else which can cause an engine to not run right first. I cannot tell you how many times that I have not listened to my own advice, and tore the carburetor apart for no good reason, only to end up finding that the real issue was caused by an easy to test component unrelated to the carburetor. It will help if you can describe more specifically what the engine sound like when it fails to do what it is supposed to. Carl
Entire Thread
Suddenly, no power!
| Tom R | 10/05/2019 7:48 PM |
Re: Suddenly, no power!
| Justhorsenround | 10/05/2019 8:15 PM |
| 52Carl | 10/05/2019 10:48 PM |
| sstock | 10/06/2019 1:21 PM |
| Tom R | 10/06/2019 6:23 PM |
| Justhorsenround | 10/06/2019 7:00 PM |
| Lightholder's Dad | 10/06/2019 8:45 PM |
| EdPruss | 10/07/2019 2:33 AM |
| Tom R | 10/07/2019 12:15 PM |
| beltfed | 10/07/2019 4:01 PM |
| Green_98 | 10/07/2019 4:39 PM |
| Tom R | 10/11/2019 12:13 PM |
| Justhorsenround | 10/11/2019 12:22 PM |
| Green_98 | 10/11/2019 12:36 PM |
| Justhorsenround | 10/11/2019 1:23 PM |
| RdsLessTaken | 10/11/2019 3:01 PM |
| EdPruss | 10/11/2019 10:19 PM |
| Tom R | 10/29/2019 4:15 PM | |
