2 members (TUTS 59, 1 invisible),
192
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Before tearing out the old cam I would check the lift of each lobe with a magnetic base dial indicator. If each gives a lift of 0.404 then it's not worn and if the lift is not down then the duration will be right also. We have a solid lifter with a push rod brazed to it to make checking easier than trying to work through the side cover opening.
Evan
Entire Thread
Timing gear and shaft, '56 235, where to find?
| showme | 10/03/2019 3:46 PM |
Re: Timing gear and shaft, '56 235, where to find?
| sstock | 10/03/2019 3:51 PM |
| Dragsix | 10/03/2019 9:53 PM |
| coilover | 10/04/2019 3:39 AM |
| showme | 10/04/2019 12:42 PM | |
