| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | How old is the soft line going to the tee at the rear axle which feeds the rear brake lines? The diameter of the hole in that line is tiny and they are known to collapse and act like a one way valve, causing your issue. You can crack a bleeder on one of the wheel cylinders to see if that frees up both rear wheels. If it frees up the wheels, replace the soft line.
