| | | Forums66 Topics128,264 Posts1,058,352 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 2,783 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,783 | "Its never the carburetor." This is my mantra. I force myself to say this over and over again. Doing so makes me test every other component which makes an engine run right BEFORE I dig into the carburetor. Even if it turns out to be the carburetor, if there is a secondary issue which was not tested and fixed, "fixing" the carburetor will not result in an engine which runs right. The other tests are simpler to perform than diagnosing a carburetor (which is seemingly, never the problem). Carl AMEN! Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
