0 members (),
69
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,092 Posts1,056,040 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Did you check the targeting of the oil pipes when you had the pan off? The troughs only supply oil to the rods at idle. Once the oil pump volume increases at cruise speed, a stream of oil squirts straight across the pan and it must hit the rod dippers as they get close to the bottom of their stroke. It's not uncommon to burn a rod bearing due to lack of lubrication if a nozzle gets bent. Jerry
